Old 05-10-2012, 02:44 PM
donnelly.me's Avatar
donnelly.me donnelly.me is offline
Default 149 Hood decals
I was thinking of freshening up the paint on my Cub 149 but the side hood decals are in terrible shape so I am going to replace those also. I am having a heck of a time removing them. I have tried sanding them off and some sticker remover. Neither one seems to be working very well. Any ideas? Thanks, Mark
Old 05-10-2012, 03:03 PM
TheSaturnV's Avatar
One-side razor blades, carefully by hand or use a small handle/holder. Spray on decal remover as the lube to get the blade under the edges. Sometimes you have to wiggle/saw the blade to get a decent bite under the decal. Heat gun can help sometimes. I would suggest staying away from WD40 or PB Blaster. While they are good decal removers, you don't want petroleum contaminants all over a surface you are about to paint.
You may gouge the paint in a few spots, just sand those out before primer.
Old 05-10-2012, 08:04 PM
I second the heat gun! It works good for me.
Old 05-10-2012, 10:28 PM
cub1450's Avatar
cub1450 cub1450 is offline
Or a 90(angle die grinder) with a scotch bright pad works great
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 05-10-2012, 11:45 PM
save_old_iron's Avatar
save_old_iron save_old_iron is offline
I have personally used this product several times. Worked great first time, every time and left the paint untouched.
http://www.autozone.com/autozone/acc...er=189453_0_0_
I have seen other friends use what amounts to a giant rubber eraser spinning on a die grinder. The friction of the rubber against the vinyl and then the adhesive removes all traces of the decal.
http://www.amazon.com/gp/product/B00...d_i=B001DUT3Y0
Neither method is inexpensive, but they are quick and very thorough.
Goof-Off works well on the decal residue but will dissolve paint also.
If you do not learn something new every day ... you are not paying attention !
Old 05-11-2012, 08:45 AM
Wire cup on my grinder removed the stripes on my 128 in about 3 minutes. Removed all the paint in about 30 minutes.
Old 05-11-2012, 09:19 AM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
Brake Kleen and a razor blade.
1200, 1450, Red 782
Old 05-12-2012, 09:30 AM
Thanks for all the ideas. Im going to try them out this weekend. Mark
Old 05-16-2012, 10:25 AM
I tried the wire cup on the drill but seemed like it didn't want to cut all the way through the sticker. Next I got out my razor scraper and that worked Great!! Only took a few minutes and then some GOO GONE for the adhesive that was left. Thanks Guys!
