Old 05-11-2012, 09:07 AM
Default Pro's and Con's of an 1882
I have found an 1882 not too far from me for sale. I know absolutely nothing about the cyclops Supers or GT's. I do know from some of the posts they have a tendency for electrical issues, of course plastic panels, and crappy paint, if I understand all of that correctly. Now with that understood, what kind of electrical issues are typical and what else should I look at if I check this thing out?
It looks to be in great condition, if the pictures aren't misleading.
Old 05-11-2012, 05:51 PM
Personally I like the Cyclops. I don't think the wiring is any worse than the 82 series all in all. Just my 2 cents. I know I'll take some heat for this but I'm not a big fan of the Mag18. Just turned an 1882 into a 2282 with a new CH22 and it's a great tractor. Look through the "Super Day" thread probably about 3 pages back now and you can see pretty much what I did to it.
Old 05-11-2012, 06:01 PM
The wiring just seems to be of poor quality, and it is far more complex than the earlier tractors. There's all kinds of relays and stuff to run the idiot lights.
Make sure the hood doesn't bind when you open or close it. About 90% of the cyclops tractors I have seen do this, and it is either a result or a cause of some of the broken plastic stuff.
Old 05-11-2012, 07:16 PM
LiamD's Avatar
LiamD LiamD is offline
Default Pro's and Cons of an 1882
DWayne,
I personally liked my 1882 and the 1864 for that matter very much. Both of them where comfortable to use, and by anyone including my son. The seat is slide adjustable and as well they have tilt wheel. The mag 18 has plenty of power, I used my 1882 too haul the fire wood and the steering brakes worked very well in the loss of traction. I had zero electrical problems with either of them and they had all the saftey switches in use. The plastics, well yes are problematic. The 1882's were cracked, but it did have a loader on it. The 1864 was like new and well taken care of. I did sell both but only too feed the tractor hobby. I would by another anyday.
Hope this helps.
Take care, Mike
Old 05-11-2012, 07:38 PM
Well I talked to the guy that has it. He took it in on trade, does not know any history of it, other than the PO had hit a tree with it and therefore there is some all thread running thru the front to hold the panels on. Other than that he says it runs great and mows great. Will have to think about it.
Old 05-11-2012, 09:46 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Dwayne,
I have had excellent success with my 2284. I have had only one electrical issue with a dirty key switch connection. I actually have used my soldering gun to plastic weld some cracks in the plastic. I have my side panels screwed on were the tabs break off. The paint is bad in spots ill agree with that issue. Its a very easy to use comfortable tractor and parts are readily available and reasonable.
Don Smith
Old 05-11-2012, 10:08 PM
My 1861 was kept outside for over 5 years in all kinds of Virginia weather.
The man who gave it to me could not get it running. It had 3 electrical connections that did not make contact.
I had a hard time finding 3 at the same time!!
I store it inside and the 1861 has been flawless for 5 years.
One switch acts a little funny, the tractor will not start if you are not sitting on the seat, but, you should not need to do that very often!!
So I do not feel the tractor has electrical issues. I am happy with it.
Old 05-12-2012, 08:54 AM
MWShaw's Avatar
MWShaw MWShaw is offline
Originally Posted by dsmithjr View Post
Dwayne,
Hearing all of the stories about the plastic panels, and having seen picture of CADplans 1861, had me thinking??? When I was looking at a 2182, the other day, why not take the body work from an older cub, and do away with the plastic stuff. I've got a pile of bodywork from the 2072, that no one seems to want, why not swap out a cyclops, make it an all metal body???? The frame of the 2182 I was looking at, and the frame of the 2072, "look" identical.
Just a thought.
Old 05-12-2012, 10:16 AM
Putting 82 series sheet metal on a 2182 would be a tough conversion because of the radiator location.
Old 05-12-2012, 10:26 AM
I have a few of each. The cyclops are more comfortable and I think the GT decks mow better than the older A or C decks. I only have one with a Command engine and it seems smoother and more quiet than the mags do but don't feel like they are as powerful. If you find one that never sat outside the paint will be okay but most of the ones are faded and the paint doesn't stick to the metal. The "rust free" panels are junk too. As Matt said, the wiring has too many plugs and corrosion problems. All the problems can be corrected so if you find a good deal on one I wouldn't pass on it.
I think the 82 series are some of the best built but they have some issues too. Like Sam said the engines are getting harder to find good parts for and I wonder how long Kohler will support them. Some people like the CV drive shafts on the cyclops but it's pretty hard to beat the good old cheap rag joints used in the 82's.
I would buy either. I think they both have there +'s and -'s.
