Old 05-12-2012, 12:33 PM
ngilson's Avatar
ngilson ngilson is offline
Default 62 original spindles ad axle
has anyone retrofitted axles and spindles from other models to work on an original
owner of
1970 cc 106,model 72
Old 05-12-2012, 02:54 PM
The right side would be hard to do to the fact the steering linkages attach on the right side and all of the other cubs attach on the left side.
Old 05-13-2012, 03:05 AM
I've never done the actual work, but here is what I do know.
An "O" axle is about the same width as a narrow frame axle. An "O" axle is about 2.75" thick at the mounting hole where NF & WF axles are about 3.25". The mounting hole in an "O" axle is 7/8" (I believe) and a WF and NF axle mounting hole is 3/4". Spindles, wheels and tires included an "O" front axle is about 33" wide, a WF (with narrow wheels) is about 35" and a WF with wide wheels is about 36" wide.
That said; if you are looking to make a number of modifications, it could prove to be an interesting project. I'm only guessing but I believe, with minimal effort, it would be possible to mount a NF or WF steering column in an "O" to get the drag link on the left side of the tractor.
Old 05-13-2012, 10:36 AM
True, if you swap the axle and steering column from a NF it could work. The Original steering column is shorter but off the top of my head I don't know how much it is.
