So I'm starting my 782 rebuild. Pulled the engine a couple fenders and the seat. Thought the engine was seized because I couldn't turn it but put a light extra into and and it budged. Guess it was just stuck and now it moves with no problem. I think I may completely tear down the series I clean it and give it a nice paint job. When I have it apart and if it doesn't seem to be worth rebuilding what is a good donor for the 782? As I pull it more apart I posted updated pictures.
You've been busy! Looking forward to your progress.
Looks like a good start!
![]() A M18 is a common replacement for the kt series one or you could put a series 2 in it.
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]()
Had a couple hours to spend on the 782 this weekend and made some decent progress. Pretty much have it down to frame. Only thing I think I have left on there is the lift which I may just keep on there. Just going to give it a thorough cleaning and maybe some fresh paint. Can or should the lift be able to be moved if its completely torn down? I tried moving it and it won't move at all! I was also thinking while I have it torn down of putting in the two front ports, does anyone have any pictures of theres or a how to?
Not the most ideal work conditions but I dont take the time to clean up and make a nice setup for myself. Just want to jump right into the cub! |
Weres the diesel???????????????
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
Give ole donovan a break he'll be getting it soon
Logan Pfeiffer 1986 cub cadet 1606 w/ spring assist, cat 0 1974 cub cadet 149 sleeve hitch 1984 gravely 5665 professional 1979 gravely 8122 1979 gravely 8102 2000 Exmark lazer Z 1978 international 184 Proud to be a member of the FFA |
Thanks for the update!
Had a couple weekends to work on the 782 and did some priming. Also a shot of the new engine shes getting. So much easier taking it apart then its going to be putting back together. I know I'm going to have extras parts
