Old 05-15-2012, 07:38 PM
theunit's Avatar
theunit theunit is offline
Default 60" Haban deck problems
hi all, purchases a pretty nice 2182 with a 60 haban yellow deck a few months ago from the family of a guy who had died. the middle blade sits lower than the other two blades and cuts so low that i have big brown strips in the yard just in the middle. doesnt look spaced or anything. is this normal? do i just need to adjust how it is lifted in the front? not shure but it is deffinitly lower in the middle. what kind of other decks can attach to this mower? btw the plastic isnt on but its not cracked! thanks
Old 05-15-2012, 08:02 PM
All 3 blades should be at the same height. I'd put a straight edge across all 3 and check and if the center is off find out what is wrong. If they are all even maybe the front is tipped down but I kind of doubt that because it should be running on the wheels.
Old 05-15-2012, 08:25 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Just a thought , he may have set it that way so as to mow a checker board pattern
Old 05-15-2012, 08:44 PM
I think the PO whacked a stump and bent the deck.
That one spindle is sitting on an angle!!
Don't ask me how I know about that!!
It is easy to fix.
Old 05-16-2012, 06:12 AM
Also, a spindle may have went bad, and a replacement was installed incorrectly. BTDT....
Old 05-16-2012, 06:16 AM
maddog784's Avatar
There may be an extra washer or two on top of the blade, between it and the spindle bearings, making it lower. Also, if the edges of the center blade are bent down, that would do it also.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
