Has or does anyone use studs on the rear end cover? The reason i ask is that i have a tiller gear box that I will be running very infrequently. With studs i would be able to take the gearbox on and off and not worry about disturbing the seal on rear end cover. Would the mount be stout enough being raised away from the rear end cover and not sandwiched up against it? Or do you just leave the tiller gear box mounted at all times?
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood. |
