Old 05-18-2012, 03:19 PM
Darrell Darrell is offline
Default Vertical to Horizontal ??
Hey Guys , I picked up a 20HP Magnum Vertical Shaft engine and i have read a few things about swapping this to Horizontal , but didn't quite understand a few things.
Has anyone done this that can shed some light on a few questions i have ???
This engine does have an oil filter mounted on the block.
I would like to speak to someone on the phone about this conversion.
Thanks ,
Darrell
Old 05-18-2012, 07:14 PM
David a Calkins David a Calkins is offline
Default vertical to horizonal
never done this ,but i did see it done on u tube .try that ,it didnt look that hard ,
Old 05-18-2012, 07:26 PM
Well,--
I done it on my M-18 Vertical
You have to use the horiz.closure plate, the block has to be drilled for a dipstick, the drain back passages for the rocker boxes (2) have to be plugged in the block or it will flood the boxes with excessive oil.
a passage has to be drilled for the oil pickup tube.
The crank has to be shortened and a new captive keyway has to be milled and a short bushing has to be made on the end of the crank for the PTO to fit on.
It can be done. prolly some things I forgot.
