I was doing some maintenance on my 1450 yesterday. I was much surprised when I bought a new Hydro Filter and rear end cover gasket and the cost of each.
![]() Anyway, while cleaning up the rear end, I got to thinking. ![]() Has anyone ever entertained the idea of drilling a hole in the lowest portion of the casting and taping it for a 1/2" MPT plug, like what is used in the rear cover. Thus, draining the fluid would seem a bit easier. I fully realize the benefits of pulling the rear cover but it seems that it don't have to be done every time.
![]() Most people do not have the capability to D&T, but, if you do I believe it would be worth while. Of course, Duke needs photos, might as well tell him what tools you used!!
Why not plumb a drain on the return line?huh
Up to 534 and counting... I give up updating my profile! |
![]() Quote:
For the amount of times the fluid gets completely drained, it would be just as reasonable to break the suction tube and just allow it to drain. Also, if you have a bent tube instead of the one with the elbow, you can loosen the nut that goes into the housing and it drain through there.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
