I've been asked to help somebody out with a poorly cutting 42" deck on a 105. It leaves 2 stripes at the outside edge of the center blade. The grass is kinda cut, kinda bent over, and mixed with a small pile of clippings in the stripes. Also, when cornering, the thing just pretty much doesn't cut at all on the outside. The blades are sharp, the belts are good, it sounds like it runs at full speed (faster than my 149), and the deck appears level. Where do I go here? Someone mentioned gator blades would help, but I have no experience with them.
Sounds like a blade might be upside-down if it's not cutting and not carrying the clippings. I know i've put them on upside down before
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
Already checked, they're on right
I will be watching this thread I have a 42 doing the same so I hope someone on here can help. I put a set of blades on mine a long time ago that did kind of the same but thats when I thought I had a 38 inch deck.
129 Plower; 72 pile;122 daily driver, 2-42inch blades 42 inch deck- 06 GMC 1500 4wd- 1964 farmall 706 |
Are the baffles intact?
----------------------------------- 106 Needs a clutch-------107 (Lent to my brother) 123 w/hydro lift & qa36--126 w/creeper and lift 127 restored--------------129 50" mowin machine 129 w/hydro lift-----------147 plow horse w/tiller 149 auction score---------782 KT17SII |
Yep, the whole deck is in really good shape, one of the best I've ever seen. Spindles are still nice and tight as well
Bump... Any more ideas?
You may have a bearing problem and not realize it!!??
![]() There are the main bearings and idlers and mule pulleys. The best way to check the bearings is to mow for 30 minutes and check the part temperatures. A non contact thermometer is very helpful here. Keeps your little pinkies from getting burned when you find a problem. ![]() Oil could be on the deck or main belt. ![]() Maybe the pto clutch is slipping, I have never seen that, but, they sell replacement parts for some reason!!
when the blades are as lined up as they get how big of a space is between the main blade and either outside blade my 42" only has 1/2 to 3/4" between the blades at the tip
