Old 05-23-2012, 10:04 AM
arijus arijus is offline
Default Hytran leak on 1782 transmision
Hello ,
There is hytran leak from hydraulic transmision housing area.
I starts only after a while- when its hot and working. There is no leak when cold.
Anyone knows what could be the cause?
Old 05-23-2012, 05:00 PM
maddog784's Avatar
Where exactly is it leaking from? That would give an idea as to where to start the search...
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 05-23-2012, 05:15 PM
Check your relief valves on top of the hydro pump.
Old 05-23-2012, 05:36 PM
Where it is leaking - it looks like area where hydro pump joins to main chasis housing .- attached one picture; and also area of trunion shaft lip seal. The top of pump where the valves are located is dry.
Can be this leak still be caused by bad valves? or its more gasket problem.. - but then its not leaking when unit is cold/ not operating.
Old 05-23-2012, 08:32 PM
CubDieselFan's Avatar
Pull the tunnel cover off and crank the tractor over, do not start it, just let it turn over. I had a similar problem with my 1572, here is a link to what mine looked like. Mine was the one of the valves leaking. Be careful with that tunnel cover off.
http://www.onlycubcadets.net/forum/s...ad.php?t=11917
Old 05-24-2012, 01:04 AM
took off the cover and took this picture. there is no leak from the valves. Looks like from mid section of the unit.
Old 05-24-2012, 07:57 AM
maddog784's Avatar
If it looks like the leak is from where the pump attaches to the main housing, there is a gasket there, but I couldnt' see it just going bad all of a sudden. Check that the bolts that hold it on are all tight.
The circular cover underneath the pump is a seal point also - there is no gasket/o-ring here, it's just metal on metal seal that has to keep in the hy tran. If you can spin it by hand, it's too loose - give it a good tap with a hammer to tighten it up in the hole.
On the bottom of the pump, where the suction tube enters, there is an male ORB to male JIC37. The O-ring could have given up on this, or the suction tube may have come loose - check to make sure everything's tight there. Careful taking this fitting loose or you can drain all of your hydro fluid out.
Last but not least, check the housing for stress cracks. It is aluminum, so some fatigue may have taken place and soem stress cracks may have occurred.
Just my
Good luck!
Nate
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 05-24-2012, 05:16 PM
Thanks for advise Nate,
Which place do you mean by "The circular cover underneath the pump".
regards,
Arijus
Old 05-24-2012, 06:09 PM
inspectorudy's Avatar
I know it seems silly but if the filter is leaking the prop fan can blow some of the fluid up on the bottom of the transaxle and make it look like it is leaking there. So check the filter and make sure it is tight.
1811 Hydro
Old 05-24-2012, 09:09 PM
maddog784's Avatar
This is the cover I was talking about.
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
