Hi,
I swapped for a 147 that had a blown engine. It came with a blown replacement K301, the original blown K321 and a 12 hp kohler that looks like a K301aqs or a 12 hp out of a quiet line. It has the muffler on it and a heat shield around the muffler but it doesn't say the model on it. Also it is physically bigger than a k301. It's roughly the same as the K321. So my question is, how can I tell what it is? I'll post pics later... Thanks, Stuart
Stuart in Hopkinsville, Proud owner of an Original, 100, 73, all of which belonged to my dad, 125 with lift, hitch and 1a tiller, 126, 147 also have a 1961 Bolens ride-a-matic, a case 222 and a case 446. |
Heres a couple pics...
![]() ![]() What do you think? Stuart
Interesting: it has a fuel pump on it....
Take a look under the muffler area. Does it still have a PTO on the crank? If not, there should be a casting mark under the PTO area of the block (K301, 321, etc). The tins, starter, etc look like QL, the fuel pump thing is only thing that looks different (maybe add-on and they did a remote tank or something?) |
That's from a 1282, 680, 1210, or 1211...I can see the extra mount brackets still attached. That also explains the fuel pump.
