Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 05-28-2012, 06:24 AM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Default pulling shrubs
Want to use my 1250 to pull out some Rose of Sharon. Any suggestions? How much damage could I do with putting slack in the chain and giving it a good wham!?
Old 05-28-2012, 09:14 AM
i usually use my truck when I pull a shrub , give it a little slack and just put it in R and then it struggles too so i think it won't do much with a 500# GT
Old 05-28-2012, 04:47 PM
Poor 104 Owner Poor 104 Owner is offline
depends on how big they are and how wet the ground around them is
I would use a tow strap over a chain on smaller dia. items the chain will not bite in as well as a strap double wrapped around the base as low as you can get it I would soak the ground 18" around the shrub you are wanting to pull the root system will mostly be in the top 18" of soil so you wouldnt need to soak it that long to get it deep enough
I would think that providing the ground is soft around the shrub and you can get enough traction you should be able to pull out a 1"-maybe as much as 2" rose of sharon
A hard yank has the potential to geek up stuff inside a rear end not saying I havent done it but couldnt feel comfortable suggesting it to anyone knowing that there is a "potential" risk of damage
Old 05-28-2012, 05:59 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
I agree with "104" the potential for damage out weights the benefits. I have had very little luck pulling shrubs of any kind. Now I just dig out around them and cut the root ball then they will come out with a little effort.
Don Smith
Old 05-28-2012, 09:33 PM
ajcombs's Avatar
ajcombs ajcombs is offline
not knowing the size of bush but ive had a 12in diameter 6 deep bush that I pulled with chain and my awd Jeep in 4 lo and I wouldnt say it struggled but if you weretrying to jerk anything your going to bend or break it in some way!
Old 05-28-2012, 09:36 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
I use a old bumper jack from a 70's car. click click click..... pops um right out
Doug
Original , 100 , 125 , 582
Old 06-01-2012, 03:12 PM
ab147's Avatar
ab147 ab147 is offline
I use a 3/8" chain and wrap alot of it around the base of what ever I'm trying to pull out, leaving alot of slack in the chain I haven't had anything stop my F350 yet.
147 w/mower deck, plow and rototiller owned for 22 years
149 new to me in 2010
2 more 149's with a a42a snowblower new to me in 2011
