Old 05-29-2012, 01:05 PM
prskier17 prskier17 is offline
Default 1650 - Differential slop / backlash question
This past weekend I finished reassembling the new-to-me 1650 that I had replaced the iso mounts, added the cross brace to the engine brackets, and worked on the steering. It was a lot of fun mowing with it finally but I really need to address the trunnion lever to smooth out the hydro response. I also noticed fairly significant backlash when changing from forward to reverse. The backlash was likely exagerated because of the trunnion lever issues but I'm wondering if this is something that can be corrected fairly easily?
Old 05-30-2012, 09:44 AM
Nothing??? hmmm.... here's another way to describe it.... If I set the parking brake (which I adjusted easily thanks to this forum) I can push the tractor forward and backward enough to indicate there is a lot of slop or backlash in the diff. I'm not sure if this can only be tweaked with shims or if it's normal or what, but any advice from the experts would be great! Thanks, Chris
Old 05-30-2012, 10:38 AM
Chris
I'm assuming you have the internal wet brake on your 1650. Lots of things that contribute to "slop" axle to spider gears, spider gears to carrier, ring and pinion, reduction gears. All of this is part of the slop. Pull the rear cover and if nothing is bad and it's not making noise I'd leave it alone.
Old 05-30-2012, 12:03 PM
Correct... I have the internal wet brake. I'll pull the cover off and take a look... and if nothing looks wrong I'll leave it alone. I'm guessing that once I get the trunnion lever / springs smoothed out it will be less noticeable. Thanks for the advice!
Old 05-30-2012, 12:37 PM
maddog784's Avatar
The backlash can be adjusted with shims. This involves taking the axle tubes off so you can remove the bearing blocks and add/remove shims. I think MattG has a write-up on his site, it would be good to take a look at.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 05-30-2012, 06:52 PM
The backlash does not need adjusting unless the pinion shaft, carrier, or bearings were changed. What he likely means by 'backlash' is that the hydro is jerky when going from forward to reverse, which is a trunnion slot/linkage problem and has nothing to do with the inside of the transmission.
