Well after getting bored on saturday i decided to start making a 2 bottom pull type plow. So far i have the main frame and mouldboards almost mounted just need to finish weld the frame then drill holes.
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4. |
Your off to a good start! Looks like your using 2 8" plows.
Are you going to make it a sleeve hitch or three point setup?
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
awesome. i have the same idea as you. i have 2 small plows but id like to find 2 of the same because mine are pretty different. im gunna make mine sleeve hitch
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
Using a 6" david brfadley on the front and a 8" brinly on the rear, not the normal brinly though. Its going to become a trailer plow like a little genius trip plow. Hopefully ill be able to pull it with my 100 narrow front.
Can't wait to see this done! I have spent a lot of time plowing with a 2x16 Oliver trip plow.
-105___ Tiller |
That looks neat! I also can't wait to see the finished product.
Nice looking fab job on the frame. I picked up a second 10" Brinly today and plan to do something similar. I want to put two sleeve hitches on an angle off a 3 point hitch mount I made for the Kubota. Then I will have a 2 bottom or can take one off for the cub. I will post pictures as soon as my Speedy Metals order comes in.
Why did you use moldboards, I have had good luck with the old lister sweeps that I took off of my 8 row cultivator.
