![]() ![]() I have a 1650 and the mower deck will start to droop down when it is not being used. I will store it with the deck up and the next time I go to use it the deck is on the ground. My relief valves have a little leak would that have anything to do with the deck or will I be chasing another problem down. Any ideas. Thank you Clifton |
it sounds as if you have bleed by on the lift control valve
I have no experience with a hydro lift but just my $.02 |
![]() Quote:
In one of the skits a person would come into the doctor and say; Doc, my arm hurts when I do this!! The doc would hit them and say "Don't do that!!". Same thing, Don't leave the deck up!! ![]() I have had a bunch of hydraulic machines, they will only stay up for a few years, they all bleed down eventually. |
Something that I discovered by accident is that if you have loosened the hyd lift valve for any reason and do not center it back to where the lift control handle is in the exact center position the valve will have a slight pressure on it even when not in use. This may not be your problem but it is easy to check. While moving the lift handle watch the sliding part of the valve to see it if it goes both ways the same amount. But as was stated all hydraulic devices droop sooner or later.
1811 Hydro "Failing to prepare is preparing to fail". ![]() |
I highly doubt that your relief valves have anything to do with this. The leak is most likely between (and including) the lift valve and cylinder. Check to make sure all of the hoses are tight. I believe that the lift cylinder on your model tractor has ORB fittings on the cylinder - an O-Ring may have gone bad. You also may have lost an o-ring in the valve body. The O-ring on the cylinder piston also may have become cut or torn, causing an "internal" leak, if you will. A good start would be to make sure all of your hoses are tight. Take it outside and wash it, then store it for the night. Come back the next day and look for fluid drips.
Best of luck, Nate
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
Both of mine bleed off when left up.
I don't have any oil leaking out anywhere, so i believe it is just bypassing in the lift cylinder. |
All Hydraulic systems have a specified leak off/down.
That said, unless you have a external leak it is most likely the oil slowly going past the spool valve--perfectly normal. The deck should drop from fully up to down in about 1/2 to 1 day. Now if it is dropping as you watch it, you have a problem that should be addressed. |
All of mine do the same thing. Nothing to worry about, it is normal.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I've always lowered my implements to the ground when it is parked.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Kind of a safety thing there. If you leave it all the way down, there's no chance of it coming down on something, or somebody by accident.
Steve, Former multiple 149 owner. Left the tractors back east when we moved to Nevada. One went to South Jersey, the other to Long Island. |
