I was curious would a pto driven tiller from a deere or kubota work with a sgt cub if i would change out the pto shaft to fit into my pto??? It is so hard to find the cub cadet tiller and was just curious. Thanks fellas.
Justin ![]() |
If the tiller is set up for a 2,000 rpm input shaft, shouldn't be a problem
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
and if not you'd be picking chunks of gear box out of the back of your head after it went boom!
Josh 1989 SGT 2072 (restored) 60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake Cub 128 with creeper and rear PTO with reverser(next project) IH built 682 and 782 that will combine to make one |
I would be afraid to put the tines in the ground!
