Old 06-04-2012, 09:51 PM
Default Wheel Weight Bolts and Where Do They GO!!??
I have never used wheel weights, I have always used fluid.
I ran up on a couple sets of weights
some paint remover, high pressure washing, and Valspar later they are ready to go on something!!
Someone mentioned they should go on the inside of the wheels, but, I am pretty sure they would hit the brakes on an 1872!?
So I guess I will have to bolt them to the outside of the wheels.
Does anybody know what size and length bolts are needed to put them on the 26X12X12 wheels of an 1872?
Since I have 2 sets, what tractor will take them on the inside?
Is there a bolt length chart somewhere to show what bolts to use with what tractor wheel?
Old 06-04-2012, 10:03 PM
bocephus1991's Avatar
I do not know if they will hit the brakes on your tractor or not. My tractor will take them though!..lol It has internal brakes. You can use some all thread and cut it to length,think thats what alot of folks do. Hope this helps some!..Brian
Brian
Old 06-04-2012, 10:04 PM
maddog784's Avatar
I used 1/2" x 7 bolts on my 23x10.50s. Logic would tell me that another 1 1/2" would do the trick. Any cub with internal brake should take them on the inside, or you can stack them on the outside - just get longer bolts.
EDIT: I used carriage bolts - makes it a whole lot easier to install. If you are doing inside and outside, I guess all-thread would be the way to go.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 06-04-2012, 10:07 PM
I use carriage head bolts. Pull the wheels off bolt the weights on then you can reach through the holes to put the lug nuts back on.
Old 06-04-2012, 10:10 PM
I purchased 1/2-13 carriage bolts 9" long at Home Depot. The rounded head goes against the wheel weight ( the square shank keeps it from turning ), then washer, lock washer and nut on the inside.
NOTE !!! The 9" length I mentioned works with my 10.50 fluid filled turfs and 8.50 turfs/ags rims using Gilson 65lb wheel weights.
Two are required for each wheel weight.
Old 06-04-2012, 10:12 PM
maddog784's Avatar
The holes in the Cub Cadet rims are square and will hold the head of the carriage bolt, also.
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
Old 06-04-2012, 10:15 PM
What Maddog said. Use 4 per wheel and put them in from the back side.
Old 06-05-2012, 02:14 PM
juniors1282's Avatar
Two bolts are plenty and I put them on with the wheels on the tractor, those wheels are heavy enough to put on with out the weights. Pretty sure the one's I used on my 1872 were 13" long to.
1966 IH cub cadet 102x2
Old 06-05-2012, 02:54 PM
Iluvtruks0's Avatar
I also recommend carriage bolts so the head stays locked into the rim while you loosen or tighten the nuts. Come in from the back side of the rim and hang both sets on that 1872. Double stacked weights look awesome.
With the external breaks on that super, you wont be able to have internal weights. I found it difficult to get the socket on the rim lug bolts while the weights are on the rim, so that is why I suggest putting the weight onto the rim while it is still mounted on the tractor.
Double stacked!!!! :
David in NC
Old 06-05-2012, 09:47 PM
Triple stacked with 12"carriage bolts...
Jeff, yours look like big bagels...
Up to 534 and counting...
