Just wondering, how many of you add some sort of fluid to your rear tires?
I run windshield washer fluid in the tires plus 90 lbs. each side of my homemade wheel weights.
Makes a HUGE difference ![]() |
I've got RV antifreeze on my All Trails, plus between 35-75lbs of wheel weights. Nothing like a firm planted feeling mowing across a 26 degree slope!
Gary '49 Farmall Cub, '62 "Original, '70 73 w/402-D Haban sickle, '71 127 w/38" cast end deck, '73 149, '76 Sof76, '07 LT1045 w/bagger, '09 GT2544 w/bunch of mods. 5 Exmarks, Kubota B2920, blah, blah, blah... |
How much fluid do you put in each tire?
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
23x10.50s will fit around 7 gallons - I have antifreeze in mine + 1 set of wheel weights. It's a great thing to have!
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
That's the size of my rear tires maddog784. Did you fill them yourself? How?
Yeah - I filled them myself. I prefer the "break the bead" technique. I lay the tire down on the floor and break the top bead. Pour the fluid in (slowly at first, just to ensure that it doesn't run out of the bottom - mine didn't have any problems here). Put some air back in and mount them back on - instant traction. I used 3 gallons of antifreeze and 4 gallons of water. I forget what the freezing temp was, I think it was something like -20, and it doesn't get that cold here.
Others on here have found some sort of drill-operated pump that pumps the fluid into the tire. Seems to me like it would take a while for all of that fluid to get through the valve stem.
I load mine with 8oz of dawn in each tire and top off with water. I keep my cubs in my garage and it never gets under 45 and I live in NC.
Actually, it doesnt take to long to load through the valve steams. i do since mine have tubes.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: ![]() |
What kind of pump do you use, Donovan?
