Old 06-09-2012, 11:32 PM
OhioTractorGuy OhioTractorGuy is offline
Default Front wheels - 129 to tube or not to tube
On my new to my 129, the po replaced one front rim with a brand spanking new cub rim, but had it tubed. The tires are so new, the little rubber mold left overs haven't worn off yet. The other rim is in need of a fresh coat of paint, but since I see it too is tubed with a nice new tire I'm curious what folks do typically wih these tubeless by design tires? The tube is leaking at the base of the valve and only appears to hold air for about a day. I think I'm leaning toward getting a nice new rim to match the other but would like to know others opinions.
Old 06-10-2012, 08:00 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Tubes are cheaper than wheels and they should last a very long time. I don't see any downside to a tube.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-10-2012, 08:04 AM
capri17 capri17 is offline
Yea Tubes are cheap and work great
Old 06-10-2012, 08:58 AM
I agree, I have tubes in all my front tires now, used to have to check them and add air every couple of weeks. Now i check them once or twice a year.
Old 06-10-2012, 09:22 AM
cubs-n-bxrs's Avatar
I agree with everyone else if you are installing tires on the rims stick tubes in.
Old 06-10-2012, 09:43 AM
ngilson's Avatar
ngilson ngilson is offline
i tube the ones in my jd 116h but i also snow plow with it i have pulled with the 106 and on loose dirt wasnt an issue but in the grass with ags on it it pulls wheelies in first so i say tube and fill.. and yes it is cheaper than tires if ya got some rot
owner of
1970 cc 106,model 72
Old 06-10-2012, 11:43 AM
I'm the rebel then....I go tubeless, unless there is a dry rot tire that has lots of tread life left on it. I figure I can always add the tube later on if needed. I check mine once a year and the tires are usually fine.
Old 06-10-2012, 04:34 PM
I just had a front tire replaced on the 147 and I wanted a tube put in but the guy mounting it said that it could be tubeless so I said go ahead as long as it doesn't leak. About a month + later it is still holding air just fine. If I need a tube I can always put one in.
Old 06-10-2012, 07:02 PM
johncub7172's Avatar
I have plans to run tubes in the model 72 as I wish to load the tubes anyway.
Old 06-14-2012, 02:23 PM
Default Tubeless for now
I ended up ordering a brand new wheel with new bearings and valve stem. The dealer did the swap for me and tubless worked. I couldn't get the old rim to look as good as a new one and since there was a brand new one on the other side, felt it would look better with a matching set.
