Old 06-14-2012, 05:43 PM
machinehead323 machinehead323 is offline
Default Gas smell in garage
Ever since I got my 1650 a couple months ago I have parked it in my garage. Dice then I have also noticed a gas smell mixed with exhaust. I already had a push mower, trimmer, pressure washer, chainsaw, gas and.... In the garage before the cub but never noticed a gas smell. I do not notice any leaks and can only guess its coming from the vented gas gauge/cap. It's a brand new cap on it. Is there anything to look for or to do to stop the smell. I don't have a shed yet to park it in.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 06-14-2012, 08:47 PM
RChristensen RChristensen is offline
Inactive Member
Every time I have smelled gas in my garage there was a leak some where. I doubt it is from the gas cap.
Pull the side panel and run your finger around under the bottom of the carb. If it is dry check the gas tank, they are getting old and I have had a couple that developed small leaks.
If you smell it,it's time to find the problem before something bad happens.
Old 06-14-2012, 09:04 PM
David a Calkins David a Calkins is offline
Default Gas smell
do you turn the gas off be for you ,turn the key off ,try that ,and check the fuel bowl ,and see if there is fuel coming out ,
Old 06-14-2012, 10:17 PM
ole 147 ole 147 is offline
If you smell gas you have a gas leak.
Turn your gas off. It isn't the easiest to find but on quiet line its along the top of the side cover at the bottom of the gas tank. Push the button in with the help of a screw driver or handle of a pair of pliers.
if that don't help, check the gas tank for leak.
I always turn the gas off on my equipment when I can.
ole 147 said that
Old 06-14-2012, 10:21 PM
Make sure that gas didn't get into the oil. It's less likely on a single-cylinder K-series than on the KTs and Magnums, but still possible. I suspect the carb needs rebuilding or the float is sunk/stuck, dirt in the needle and seat, etc. Time to pull the carb off and see what's going on.
Old 06-14-2012, 10:32 PM
Good advice from our fellow forum members.see any leaks around the carb bowl?
Up to 534 and counting...
Old 06-15-2012, 05:38 PM
Yeah mine leaks around the carb bowl where it connects to the carb- I need another gasket but I can't find one- I turn my gas off when I'm not running it but it still makes the garage smell. It's an attached garage so it's not terrible, unless I forget to shut the windows on the car.
Old 06-16-2012, 12:25 AM
I would say it's time to get a new bowl assembly.
But if it is like my shut off it don't have a bowl.
Old 06-16-2012, 01:24 AM
Poor 104 Owner Poor 104 Owner is offline
you can get bowl gaskets at farm and home stores just got one the other day for $2.29
Old 06-16-2012, 08:28 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Gas in the garage....
I've noticed this too when my brother was working in the garage.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
