Old 06-23-2012, 11:25 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Tire sizes
Ok so as I am gathering parts for the 126 rehab coming up in the fall/winter. I am thinking of installing some bigger rubber on the corners. So my question would be what is largest size tires I can swap for the 23*10.5*12? Would a 26*12*12 tire fit the rims? I know I'll have to raise the fenders a little and have already started the plan for that. My concern is what size will fit the rims only..I need the tractor with higher ground clearance for my plants and attachments. Thanks Earl
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 06-23-2012, 11:36 PM
Merk Merk is offline
26 inch tires will only gain you 1 1/2 inches of height. Not worth the added cost of the tire.
Old 06-23-2012, 11:51 PM
EarlJ's Avatar
I found some Carlise ags at millers for just $8 more than the 23". I was out at Vince O's today and Allens tractor had some big meats on it and that's what I was thinking of but I failed to get the size of the tire.
