Old 10-13-2009, 09:58 AM
MFP8055 MFP8055 is offline
Default Ball in drive shaft coupling
The 1650 service manual tells of the need for a ball in the coupling between the drive shaft end and hydro pump shaft. The one that was in the coupling escaped during disassembly. Is this component critical since the coupling ends are pinned to the shafts? Does the flex joint allow enough movement to cause a problem? If so, what does the "ball" look like, or can a substitute be used?
IH 1650, CC 1210, 1610 and Bolens 1257
Old 10-13-2009, 10:15 AM
I don't have much experience with them and I don't know what kind of results you will get running without it.
The Ball, is a simple ball bearing, though I have never looked to buy a single ball bearing, it shouldn't be too hard to find. Some of our sponsors may have them, your local Cub dealer may be able to get one, or your local bearing house. The ball fit's inside the "cup", it isn't tight by any means but it fills the entire hole.
Old 10-13-2009, 11:02 AM
This is what is in the Parts Manual.....
Old 10-13-2009, 11:13 AM
I see the ball is 5/8". Wow. What might have fallen out of the coupling when I took it apart was not 5/8"! It may have been worn down, because I know I could find a ball that big on the shop floor.
Old 10-13-2009, 11:15 AM
Not that it makes a big difference, but my model 1650 takes two flex disks (rag joints) in the rear coupling.
Old 10-13-2009, 11:36 AM
The ball helps center the driveshaft. A good hardware store should be able to get it. Oh, and how does the end of the driveshaft look? If the ball was worn, I bet the driveshaft is really worn.
Old 10-14-2009, 12:34 PM
There is no noticeable wear on the end of either shaft. It makes me wonder if the P/O had removed the ball at some point. Again, I'm not sure what was there, since I never found anything. I've got the ball on order from my local dealer.
