Old 06-24-2012, 07:37 PM
PaulS's Avatar
PaulS PaulS is offline
Default Fixed front wheels
The front wheels on my 54 inch mower deck were really wobbly. EricRand I took them off and discovered not only the wrong bushings in the wheels but the axle bolts were worn halfway through. I ordered new axle bolts and they came in. We headed off to Lowes this afternoon and found steel bushings that will fit. They were a little loose in the one end of the wheel so we cut an expansion spring and put it between the steel bushings inside the wheel and it provided just enough pressure to keep the new bushings pushed out. If I had let them go in they would have covered up the hole inside for the grease. It worked very well and I now have front wheels restored to near perfect condition.
Old 06-24-2012, 10:36 PM
Sounds like a good fix
Old 06-26-2012, 11:11 PM
EricR's Avatar
EricR EricR is offline
I loved that very easy fix, . I just wish all problems were solved that quick, LOL.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 06-27-2012, 11:02 AM
I totally agree!
Old 06-28-2012, 12:39 AM
fleetlines's Avatar
fleetlines fleetlines is offline
Sounds like a good repair. The expansion spring was a very good idea.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
