I am looking for some pictures or a thread that explains the complete wiring harness/diagram for a 2072. The other night the deck would just stop out of nowhere.
Last night I went to start the tractor and there was nothing. I jiggled the clutch/brake and then it started. I think I have some loose wiring or some bad relays or?? I noticed that the seat switch has been disabled as well as the switch on the dash for the deck shut-off if you reverse the tractor. Is there a safety switch for the clutch too?
Check my last post in this thread.
http://www.onlycubcadets.net/forum/s...?t=6688&page=2 |
Wiring diagram sent to the E-mail address listed in your profile.
Thanks for the help! Now if I can figureout all the issues!
I've got my 2072 apart right now if you need any pics.
Don Smith https://www.facebook.com/SouthernKentuckyCubCadetClub IH 982D aka "The Big Red Smoker" BRS w/3pt hitch CC 1572 aka "The Big Yellow Smoker" BYS w/3pt hitch-PTO Brinly Cat 0 3pt plow-Brinly sleeve hitch plow Custom Hydraulic lift disc-Haban Blade-Brinly Cultivators Cub Cadet lawn trailer and lawn sweeper |
Just trying to figure out why the deck won't stay on... will be mowing along and the deck will shut off. I've been told to try adjusting the clutch next... my other issue is the leak in the rear end! AARRGGHH!!!
When my 2284 was doing similar it was shorts in the ignition switch and wiring. I cleaned all the connections,tightened all the safety switches and made sure I had no bad wires and never had another issue.
I had to remove my rear end and remove two broken bolts from my 2072. Thanks to Dwayne and his buddy everything went smooth. I posted a thread on it if you do a search.
