Old 06-28-2012, 10:42 AM
Atunink's Avatar
Atunink Atunink is offline
Default Filling rear tires
Maybe this is a silly question, but what are the advantages to filling your tire tubes with windshield washer fluid?
Old 06-28-2012, 03:08 PM
It keeps the inside of the tubes nice and clean.
It’s cheaper than Scotch.
It adds weight to the rear of the tractor.
Old 06-28-2012, 03:13 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Weight for added traction. If you live in an area where it might freeze, then you need something that won't freeze in your tire. So windshield washer fluid can be bought that is good for -20 degrees F or so. My rear tires will hold 7 gal. of fluid. If you are talking about 7 or 8 pounds per gallon, you would be adding 49-56 pounds per wheel! RimGuard (beet juice) weighs over 10 pounds per gal!!! Hope this helps.
