Old 07-04-2012, 08:55 PM
cmatthew's Avatar
cmatthew cmatthew is offline
Default kohler command pro 7hp?
I have had this engine for a little while. I have put about 4 to 6 hrs on this thing. I changed oil once at a few hrs and just changed it today. Is it OK to still smell gas in the oil?
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 07-04-2012, 11:34 PM
Vince_o Vince_o is offline
no
Was the pump or float leaking? Im guessing its still leaking. Is the dip stick reading a bit higher every time you check it.
Old 07-05-2012, 12:01 AM
cmatthew's Avatar
this motor is brand new. i assumed that the rings havent seated quite yet. the oil level hasnt risen much that i can tell. there are no leaks of fuel anywhere. fuel in tank dowsnt go down either.
CC 123
Brinly Lawn Rake
