Old 07-25-2012, 10:59 AM
gregfromny's Avatar
gregfromny gregfromny is offline
Default 124 trans question
how much gear oil does a 3 speed 124 rear end call for? while i have the shifter out to repair it i figured i should change the gear oil while i have it apart.
Old 07-25-2012, 11:15 AM
fil it until it comes out the plug on the back of the rear end
Old 07-25-2012, 11:16 AM
gregfromny's Avatar
ok thats easy enough i looked in the manuals and it called for sae 30 motor oil y not gear oil?
Old 07-25-2012, 11:19 AM
yea, im not sure you can put in hytran or the 30wt or do what i do put in 80-90 gear oil
Old 07-25-2012, 11:23 AM
gregfromny's Avatar
ill see what the part store has today when i get to town
Old 07-25-2012, 11:32 AM
alright you do that
Old 07-25-2012, 06:21 PM
jcsmith jcsmith is offline
Default transaxle oil
I use Rotella HD 30 wt in motor and transaxle. Rear takes 7 pints . As cubcadet says it will just start coming out the fill plug on rear cover, assuming you have correct cover with plug 1/2 way up. Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 07-25-2012, 06:33 PM
gregfromny's Avatar
also before i drained the oil i fired it up to move it to make changing the gear oil easier and it wouldnt move when i let the clutch out it stalled out. what would cause this?
Old 07-25-2012, 07:18 PM
gregfromny's Avatar
i had it moving today. its the first time since may!!!!
Old 07-25-2012, 07:49 PM
good greg what was wrong with it and jcsmith is right 7 pints
