I have a lead on a CH18S Spec 62588. It looks like a Cub spec number. The starter doesn't work and its missing the muffler. Other than that it is complete including electric clutch. For $150, would this be a good transplant assuming it works are described? Does anyone know right off which cubs came with a CH18S?
CH18 came in a 2185 and probably others. You can turn it into a CH22 with a carb change. Mid West Super Cub has an adpater that you can use to hook up your drive shaft. Look for a muffler for a 2284 1863 1864 part # 751-3110
http://www.midwestsupercub.net/
I don't know much on this topic, but I do know it's been done. Here is a video on YouTube I thought you might like to see... http://www.youtube.com/watch?v=MsKfvjlkwz0
-105___ Tiller |
After some research I found this spec number came from a Cub 2183 or 2184 built between 93 and 97 or a 2185/2186 from 94-02? I'm going to get it and give it a run. Thanks for the info! I hope I can get there before someone else does. Wish me luck!
"Quote: I have a lead on a CH18S Spec 62588. It looks like a Cub spec number That engine was made for MTD. " We are both right! An MTD built Cub Cadet! ![]() Thanks again! |
I put one of them in my 682 and it works fantastic.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
On page 17 in the Mid West catalog part # CHC
I have the engine on my bench. I ordered the starter and muffler on eBay. Now on to electrical and drive shaft.
Which carb do I need for the 22hp upgrade? Any other suggestions for the drive shaft? I'm sure the part recommended above will work but it's $55. Id like to fab something if possible. Wiring suggestions? |
