Hey guys I broke the pin that couples the drive shaft to the engine.Can anyone tell me what pin I need.Also I am having charge issues I did the f to ground and the motor did change so the Soga cheque led out ok. I TRIED to find a VR no luck yet.Are there any adjustments I can make to the VR and what tools would I need?
THANKS. |
Should read s/g checked ok.
A 1/4 x 2" will do it make sure you use a spirol pin that has a double coil it will last longer. There was someone that posted a great VR write up with pics here a couple months ago that will give you all the info you need to adjust yours.
Thanks Duke
Your welcome and I'm still trying to think of the posters name so I can find that thread for ya.
The pin that couples the engine to the driveshaft is a solid hardened steel dowel pin, NOT a spirol pin. Last I checked they were still available from Cub Cadet.
