Old 07-28-2012, 02:06 PM
ccannon222 ccannon222 is offline
Default 44C on 1250
I have a 1250 with a rust out 38" deck with bad spindles. I picked up a 44" deck/carrage/mule drive that was being used on a 1250. The person I bought it from said the previous owner took the 44" deck and carrage/mule drive off of a 1711 and changed the center pulley to the correct 5" 3/8 pulley for a 44A. I believe the deck I have is a late model 44C. Before attempting to put the deck on my 1250 I changed out the 5" pulley for the 4" "speedup" pulley. I followed the belt chart and purchase belt IH-59971-C1 3/8 by 78". This belt is way too short. I tried a old belt from my 126 with 42" deck. This belt is 80" long. It is at least 2" too short. Has anyone ran into this problem before?
Chris
Old 07-28-2012, 03:32 PM
I compared my mule drive to one I have for a 129 with 44 deck and I noticed that the pulleys are the same but farther forward on the 1711 mule drive. The previous owner must have swapped out the 5/8 pulleys for 3/8. I ended up using the 129 mule drive with the 1711 carrage. With the 4 inch center pulley the 79" belt is borderline too long. I'm gonna give it a try and if it's too loose, I will swap in the 78" belt.
