Old 07-30-2012, 10:42 PM
Default Kohler Command problem
I got a problem on my 1863 with the Command engine. I took this tractor on trade about 1 year ago and the PO told me the engine had overheated and the valve seat came loose in the head. He took it to a machine shop and they repaired it and he put it back on. We traded and I never used the tractor except for a few times pulling a sprayer. It has been parked in the barn and now I'm wanting to sell it.
Over the weekend I noticed the engine doesn't seem like it is running at 3600 rpm. I used my contact tach and found it was only running about 3000 rpm. I adjusted the throttle cable and the high speed adjusting screw and got it up to 3500 but it runs rich and doesn't sound good. When I move it to idle it dies. I thought that maybe the carb is dirty so I removed it and cleaned it but that didn't help. I did notice that I'm getting some oil out of the breather tube when I had the cover off the air cleaner. I checked the crankcase vacuum and have about -5"WG at the dip stick tube.
I ordered a cylinder leakdown tester today to check for problems with the valves and rings but got the thinking maybe it's in the ignition.
What do you guys think could be my problem?
Old 07-30-2012, 10:46 PM
Your engine may be getting warm if you see this!
Old 07-31-2012, 06:22 PM
Leadslingingdaddy's Avatar
Yea not good...Wow... normally you would see that from a lean running engine..
Old 07-31-2012, 07:11 PM
That is how I got it. The PO said a mouse built a little house up in the engine and it got too hot.
Old 07-31-2012, 09:01 PM
Sam Mac Sam Mac is online now
Little house is just a bit of an understatement from the looks of that. I'm wondering if you still have a mouse problem and if they dined on the wiring under the blower housing? My guess is that engine got hot enough to hurt it.
Old 07-31-2012, 10:12 PM
PaulS's Avatar
PaulS PaulS is offline
A mouse nest atop the fan shroud caused me all kinds of problems. The mouse chewed the kill wire and made a mess under the shroud and under the Tins around the jug causing it to run hot. I then had to replace the valve covers because they were cracked and leaking and caused another mess under the tins around the jugs. Then I had a real mess when the rear oil seal began leaking and lubed the entire outside of the engine. If the fins are kept clean mine runs fine but gets hot if they are gunked up.
Old 07-31-2012, 10:39 PM
Look at these Autolite 3924 plugs with less than 1 hour of run time.
Old 07-31-2012, 11:15 PM
jcrews's Avatar
jcrews jcrews is offline
Oak
That looks like the cylinders were packed in bearing grease.
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
