Here is a quick picture of a cable lift to replace a lift rod on my 149 with a QA42A snowblower. The space between the lift arm and the mounting bracket in the front was too small for a lift rod, so this is what I came up with for under $4.
Cub Cadet 123 told me about this setup when I first got my QA42A...It really does work great, and is much cheaper/easier than making a lift bar!
-105___ Tiller |
i done did the same thing with my qa42a on my 123 when i first got the blower. came without lift rod. the cable worked good until i fab'd my own rod.
CC 123 402c Sickle Bar, 48" Mower Deck QA42A Snow Thrower, 42'' Push Blade IH Back Blade and Rake Brinly Seeder/Aerator Brinly Lawn Rake Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc |
I think i would but a bushing in the holes for the cable to go through that way you don't ruin the lift arms. Just my $.02
Last winter I used a cable on a dozer blade and cut the cable in short order. I would also recommend the grommet if not the rod. I suppose the blade had more vertical movement than a thrower.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights 72, Serial #231093, K161S Serial #C281773, 36" deck 149 & Original Yard art 1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch 1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted 123 FEL and weight box 10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller |
I put this together with some stuff I had around the house when I started plowing with my 125. It is 1/4 aircraft cable. I attached to the blade and lift with shackles so I could remove it quickly. It is much better for pushing snow that the rod could ever be. It always floats.
Steve, Former multiple 149 owner. Left the tractors back east when we moved to Nevada. One went to South Jersey, the other to Long Island. |
I've only used it for my throwers and not for my blades since I always seem to have a rod lying around for them. I'll have to give it a try since it does seem like it would float a little better.
The bad/good news is that a day after posting this, I discovered that the 149 (pictured) is going to need a new piston and rings and maybe a bore job. There is just too much slop in it and too much oil in the head after removal to inspect the head gasket. Well, it will run better than ever since I've had it when it's done! Cub Cadet 123
