Can anyone tell me what should be holding these support arms the front has hitch pins through the tensioner but he has the back bolted? I have seen some in older posts that looked like it was a sleeve in between with a bolt through it. Any hints or pics would help? Thanks Sam
Sam My Cubs 108 & 1250 & 104 Tiller, snow thrower, Plow
Sam, the missing long bolt attaches the belt cover for the gear box to tiller pulley.
Link to the manuals from the tech section of the site. http://www.onlycubcadets.net/forum/s...ead.php?t=4698 |
ok thank you thought it was a sleeve in between. I will replace the bolts with 1 long one. Will make it easier to install the guard too. Thanks very much!
I think it's a spacer with the bolt going thru it now that I think about it. Your welcome!
I'm not sure of your question but hope this helps:
There is a bolt and spacer missing on the belt tensioner. You aren't showing the pulleys from the back of the tractor. It may be missing. You also need the lift for the chain. It looks the shaft is there. Hope this helps. Edit: "pulleys from the back of the tractor" means gear box. The "lift" means the 3 pt. I get it now that you wondered about the spacer. It needs the spacer to keep from collapsing. Tisk, Tisk, I couldn't even come up with "gear box" for the post 'cause I was hot and exhausted. Hope the pic helped.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights 72, Serial #231093, K161S Serial #C281773, 36" deck 149 & Original Yard art 1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch 1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted 123 FEL and weight box 10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller |
