I've got a 1210 that will slip from wide open throttle to a lower speed while running. It it runs great at high speed (3000 RPM) with no vibration. As it slows, I first notice a little more shake, and then have to open the throttle again. I don't see any obvious tension adjustment at either the lever or engine end. I imagine this is a fairly standard component since it looks real similar to the one on my 1650. Any advice is appreciated.
IH 1650, CC 1210, 1610 and Bolens 1257 |
You probably nee to either replace the throttle cable or take the lever out of the dash and try to give the rivet a good whack with a hammer and tighten it back up.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
Yep, what AJ said....
The cable is in good shape and not slipping. It's the throttle lever that slides down from full open to mid-range when operating. Sounds like a job for a big hammer. Thought i could get away without pulling the fuel tank and removing the speed control. Wishful thinking on my part.
