Old 10-22-2009, 11:32 AM
MrChic's Avatar
MrChic MrChic is offline
Default Adding hydraulics to a narrow frame hydro
Ok guys. I really want a hydro lift on the 105 but can't afford a factory lift. I have an old Bolens hydro tractor with lift cylinder, hoses and control valve. This runs of an Eaton pump that also runs the trans. So if I fabbed up some brackets to get the cylinder mounted, how would I plumb it? Would I need to swap in a ported hydro from an 82 series tractor? One just sold near me for like $45 on epay. I am more interested in usability than originality. Thanks for the help. Oh yeah the control valve that is on the parts tractor has three ports and the lift had up/down and float originally.
Mike
1968 CC 105
"Chug a lug a luggin' 5 miles an hour on my International Harvester"
"Don't forget that ignition key !!"
Old 10-22-2009, 11:34 AM
Use the valve and cylinder, and go to a junkyard and get a car PS pump to run the hydraulics.
Old 10-22-2009, 10:47 PM
MrChic's Avatar
OK, but wouldn't a ported hydro pump do the same thing? Then it would look less frankensteinish. I am not worried about modification but the less the better. Can I swap a non ported pump for a ported?
Mike
1968 CC 105
Old 10-22-2009, 10:57 PM
Yes. However, you may have issues routing the hydraulic lines. There isn't a whole lot of room under the NF tractors for stuff. If you're going to go that route, make sure there's room up there somewhere for the hydraulic lines.
Oh, and connecting them is going to be next to impossible under there... There's no place to put the wrenches without a removable tunnel cover. I am not a fan of cutting holes in the frame either....that's gonna look far worse than a PS pump on there. The PS pump setup would also be easier to remove and return the tractor to it's factory setup if you for some reason want to sell it and get a different tractor to install it on.
Old 10-23-2009, 12:48 AM
MrChic's Avatar
Hey Matt thanks for the advice. Maybe I will just look for a Cub with on board hydraulics. Did any of the NFs come with hydro lift standard?
Mike
1968 CC 105
Old 10-23-2009, 01:07 AM
ihnick's Avatar
ihnick ihnick is offline
The 147 came with electric lift. But I think the rest of the narrow frames came with manual lift
Old 10-23-2009, 09:21 AM
Mike,
The hydraulic lift on the NF's was optional.
