Old 08-17-2012, 04:03 PM
IHCUBCADET's Avatar
IHCUBCADET IHCUBCADET is offline
Default Sleeve Hitch Lift Pin
I finally got the whole rear setup I need except for the rear sleeve hitch lift pin, I figure rather then pay over 20 bucks online I could just make it afterall there is not much about making in at all. What is the normal length of this pin, and what is the lenght of the extended one that i se online. Any suggestions on which size I should choose to use? Thanks so much for any help!
International Cub Cadet 71 with deck
International Cub Cadet 108 with plow, deck, chains, single bottom plow,Sleeve Hitch.
IH Cub Cadet 122 project
Case 444 withs ags, plow
Old 08-17-2012, 07:42 PM
mmzullo mmzullo is offline
How's this?
Old 08-18-2012, 03:52 PM
IHCUBCADET's Avatar
Awesome, thanks!
Old 08-19-2012, 05:54 AM
cdlong's Avatar
cdlong cdlong is offline
I purchased one from "Jeff in Pa". It's longer and the tiller adjustment pin handle doesn't contact the fender pan on my 1450.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
