Old 08-18-2012, 09:20 PM
IT1450 IT1450 is offline
Default Cub cadet 1650 What should I do
Hi guys I got a 1650 given to me by a friend of my dad's. the tractor is complete minus the engine which he put into his sons 108 for tractor pulling. Im not quite sure what to do with it, should i use it for parts for my two 1450's. I also have a 10 hp kohler and a 20 briggs should i try to put one of them in it? if so what engine do you think would work better would the 10 be strong enough to run the hydrolic lift? I would LOVE to know your guys and gurls opinion on what to do!
Old 08-18-2012, 09:49 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
I would love to have a 1650, but personally, I would want the 16 HP Kohler! That's why it's a 1650!
Old 08-19-2012, 12:04 AM
Price was right! Pictures would help
Old 08-19-2012, 07:59 AM
I'll post some pictures when i pick up the tractor, I forgot to take them when i went to look at it
Old 08-19-2012, 10:20 PM
IH Cub Cadet IH Cub Cadet is offline
I'm not sure the briggs would fit. The 10hp might get you going until you can find a larger hp engine. But - keep in mind, there were a lot of 10 hp Cub Cadets that do a fine job. I've got a 109 that I am giving a workout and at first glance, I thought 10 hp wouldn't be enough, but this tractor with 44 inch deck seems to do fine. Easy on gas too.
Good luck,
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 08-19-2012, 11:41 PM
Donovan M.'s Avatar
you can send it up my way
Donovan:
62' Original-fenders
Old 08-20-2012, 09:54 AM
I agree I would like a 1650 so I'd hang on to it and try to find a 16 HP kohler for it.
Old 08-20-2012, 11:33 AM
fleetlines's Avatar
fleetlines fleetlines is offline
I think the 10 would power it enough but I'd hold out for a 14 or 16 hp depending on the condition it's starting in.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 08-20-2012, 02:39 PM
Good luck,
Bill
The 10 hp kohler I have is out of my brothers 109, he put a 14 hp in it to get more power for lawn tractor pulling. The 10 is a great little engine and it will run the transmition but will it run the lift?
Old 08-21-2012, 02:43 PM
cdlong's Avatar
cdlong cdlong is offline
Put a 16 back in it!
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
