I had the K321 out of my 149 to remove balance gears and troubleshoot the non functioning ACR. While I was there, I removed and cleaned the head, adjusted the valves, and cleaned and rebuilt the carburetor. Now that it is back together, it is not running right. It starts and idles, but hesitates or even flat out stalls when I open the throttle. The carb is at the settings in the manual. I reset the governor arm as described in the manual. The valve clearance is to spec. I used a new head gasket and torqued it to spec as well. Any suggestions on where I should start my troubleshooting?
Steve, Former multiple 149 owner. Left the tractors back east when we moved to Nevada. One went to South Jersey, the other to Long Island. |
Read this tread. It's off another forum.http://www.cubcadetcollectors.com/fo...roblems#p22617
I'll look into that stuff. Thanks. Of course it was running fine before I took it apart. I just wanted to clean it up a little. I know, it it ain't broke...
Did you make sure you are getting a good fuel stream to the carburetor? Might be something in your tank that broke loose while tearing it apart...
It runs now!
I went back into the carburetor and I'm a little embarrassed to say that I had the needle upside down! Once back together, it still wouldn't run right and that turned out to be something that clogged the inline filter that I out in the fuel line. Filter replaced, carb re installed and it runs better than ever. Thanks for your help.
starts and idles...recheck the carb float level and main jet (the idle screw/jet operates on its own as far as I know...doesn't come into play when load is applied). might want to inspect the plug also to check for heavy carbon build.
I'm obviously an amatuer here but until the pros arrive, I would do a continuity check on the wire coming from the points and also on the plug wire. |
Teejk. Look up a couple posts. It was a carb issue. Mistake during reassembly.
I saw your post after I hit the "post" button (it wasn't there when I started typing! I type pretty slow and am easily distracted). But have to ask...when you say "upside down"??? anyway glad you got it figured out...for me there is always a sense of pride in keeping the old iron running (my 1250 is one of the first and even though my wife hates it, no tin replacement for me as long as I can buy parts).
