Old 09-02-2012, 11:57 PM
JSFRIED215 JSFRIED215 is offline
Default 1641 no start lights on
i have a cub 1641, getting no power to starter, has pto engaged and depress brake light on in the dash. anyone have any ideas. should i start at the brake pedal switch? has new battery starter and solenoid. power going into the solenoid and none coming out. all started by sluggish starting. would have 12 volts going into the solenoid and like 3 coming out. now its down to no power out of the solenoid. need help asap. grass is getting talll. thanks
Old 09-03-2012, 07:10 AM
Vince_o Vince_o is offline
Sounds to me like you fixed your own problem. No power out of the solenoid.
To check the solenoid do this. Make sure the wire from the key switch has power on it, its usually red or orange, when you turn the switch to START
If you have power then see if there's power on both poles. If there's not then the solenoid is bad.
If you DON'T have power to the red or orange wire leading to the solenoid, you have a safety switch problem.
Remember if the little red/ orange wire has power on it, ALL SAFETY switches are working.
Also I'm guessing that your PTO switch is disengaged, pushed in.
Old 09-03-2012, 11:37 AM
i have put 2 different new solenoids on this. still nothing . i have 12v going into the solenoid and coming out the ignition side. but not the second large wire going to the starter. tested all all switches they seem to be working. but depress pedal light and pto light on. I hear a clicking not outta the solenoid but where the drive shaft comes out the back of the motor. haven't taken the medal off to see back there. is that where the diodes are. could that be bad?? help pleeeeeeeeeeeasseee... and also tried to jump solenoid from post to post and starter doesn't spin.
Old 09-03-2012, 04:28 PM
It sounds to me like you are having an issue with the brake or PTO switch. The solenoid will not engage when those lights are on. The clicking you are hearing is probably the fuel shut down solenoid turning on and off as it should. You wouldn’t hear a diode. I suggest that you PM Roland with the serial number and model of your tractor and ask him to send you a wiring diagram for your machine so that you can trouble shoot it.
Old 09-03-2012, 06:29 PM
ajgross ajgross is offline
Inactive Member
If you jumped the solenoid and nothing happened then you probably have a starter issue. Either the starter is bad or the bendix is stuck.
AJ
Old 09-03-2012, 06:36 PM
AJ
I'm not sure about that, looking at the parts diagram on the Cub site it looks like the 1641 has a solenoid that is separate from the one on the engine. Looks like the first one has to engage at the same time as the engine solenoid. Gotta be one of those cheap fixes once you find out what the problem is unless the clicking he is hearing is the starter turning to turn over the engine and something is locked up.
Old 09-03-2012, 07:33 PM
Im guessing he was talking about the one on the tractor, not the one on the starter.
Aj
Be sure you watch what you say about jumping things out, people her will threaten to call lawers on ya!
Old 09-03-2012, 10:34 PM
cubs-n-bxrs's Avatar
LOL Vince I got yer back
Old 09-03-2012, 10:56 PM
Inactive Member
And where did i recommend jumping anything out?
AJ
Old 09-04-2012, 11:46 AM
No where AJ its the word, sends black helocopters over your house, LMAO!
