Old 09-06-2012, 11:06 PM
Outdoorsben Outdoorsben is offline
Default K301AS Carb question
I'm most likely going to pick up another 123 hydro lift as a parts/winter tractor. It's in a "neglected" state. I know it needs a motor/gen and a carb. I've replaced a motor/gen on my other 123 and have part #'s for that alread. I can't make heads or tails of all the carb info, though. It's a K301AS spec 4759B and i've looked at a few carb's and it looks like the kohler part # would be 47 853 21-S. Looking at the spec sheet I see a K301-4759 works for that carb. Is there much a difference? Would that carb work? Any help would be appreciated.
Old 09-07-2012, 06:38 AM
Look for a used #26 Kohler/Carter carb.
Old 09-07-2012, 01:17 PM
I have a few used ones in various degrees of missing parts. I"m looking for a NEW one for this tractor so I get it running now then I can mess with all the other parts I have to rebuild one or two of them in my spare time.
Old 09-07-2012, 01:33 PM
tractordude tractordude is offline
kohler# 47 853 23-S list price $201.94
Old 09-07-2012, 04:10 PM
There are part #'s 20-S thru 30-S. All are similar pricing but I know a guy who can get it for about $100. Just need to know the proper part #.
Old 09-07-2012, 05:17 PM
You can't really buy a new equivalent carb anymore. My guess is if you buy one of those, you'll either get a Walbro non-adjustable POS, or some terrible-quality reproduction of the original carb.
It takes perhaps a couple of hours to rebuild a carb if you have all the parts...either find the parts you are missing or buy a complete carb and rebuild it. Buying a new one doesn't really make any sense at all.
Old 09-08-2012, 04:44 AM
Vince_o Vince_o is offline
If you body is good, just get all new parts, or if you can put the bushing in the throtal shaft. Any kohler dealer can get you the right parts, or contact Chris in the sponsers adds, and he will hook you up with everything you need. I took a good body and put nes jets and fuel bowl on it for a guy here on his power king. He said it never ran so good. Its amazing what new jets and bushings will do to a carb.
Like Matt said, the fixed jet carbs arnt so good. I have 2 on my supers, they sound as nice as Allens did when it left here with a 26 adjustable on his 1872.
