Old 09-12-2012, 02:54 AM
rj4374 rj4374 is offline
Default Hello from Kentucky
This is my first Cub. It's a 1772d model, and also my first time ever joining a forum. I.love the Cub. It's heavy, stay's on the ground, and does not beat me to death. I have a serious back problem. I have one of the cheaper j.deere's model L130 it's not bad but the Cub is much better. The Cub is a diesel you guy's probably know that from the model #. I do have a problem with it. When it gets hot or about an hour into working it it starts cutting out. It does not quit just sputters and goes on and it keeps on doing this. I'm trying to figure it out with no luck. hoping to learn more about the Cubs here. It's good to be here.
Old 09-12-2012, 06:31 AM
rj4374
Glad you joined us.
I am not going to be any help on the diesel but a lot of the guys here have them and should be along shortly to give you some help
Old 09-12-2012, 07:05 AM
Nice first cub!
Got any pics?
Old 09-12-2012, 01:12 PM
Glad to have you!
Old 09-13-2012, 09:49 PM
wawcub47 wawcub47 is offline
hi rj welcome to the club! glad to have another Ky. member. Im sure there is someone who can help you. Again welcome.
Old 09-13-2012, 11:26 PM
don't have any pic's yet.i will be getting some soon and post them.thanks rj
Old 09-14-2012, 04:06 AM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Welcome to OCC. Glad to see another KY smoker! I also have the diesel and it would help if you defined "hot" a little better. I have to very regularly clean my radiator. On the advice of DX I use a quality antifreeze and distilled water and I also use diesel fuel additives with every tank. I can run the BRS all day and stay in the normal range. There are lots of diesel owners that will be glad to help.
Don Smith
Old 09-14-2012, 09:11 AM
Welcome to OCC, glad to have you here.
Old 09-15-2012, 12:41 AM
Fastbuck Fastbuck is offline
Default Northern KY Cub Cadets
I've been lurking on the group for a while. I have an 1872 which I purchased new back in the late 80s. I am in the process of buying an 1811 which will need some TLC.
I am a retired jet engine mechanic, engineering test tech, wrote maintenance manuals for gas turbine engines for a year or so, and worked on experimental and development jet engines as a member of an Evaluation Engineering Team.
A total of 37 years experience working on and with jet engines.
I am about 25 miles south of Cincinnati, OH
Old 09-15-2012, 09:54 PM
Welcome to OCC! Glad to have you!
