Old 09-16-2012, 12:52 PM
ozarkarky ozarkarky is offline
Question Flywheel "S" and "T" markings
Were the "S" and "T" flywheel markings initially painted on, or were they stamped into the wheel?
Are they really tiny, because I have looked and looked, and cannot find them.
On the K301, they are located through the site hole just behind and below the starter / generator, correct?
Old 09-16-2012, 04:06 PM
David a Calkins David a Calkins is offline
Default flywheel s and t
they are stamped ,but they are their
Old 09-16-2012, 10:04 PM
samiam44 samiam44 is offline
I wonder how accurate setting timing to a letter in a hole in removable sheet metal is anyway?
Anyone with puller building experience comment on if the "T" and "S" were accurate within a degree on Kohler K-series.
Michael
Old 09-19-2012, 06:07 PM
teejk teejk is offline
Michael
LOL...I changed the motor on my 1250 (was beat-up pretty bad when I got it) to a 16hp K341 20 years ago...danged if I can find the timing marks either and like you have to wonder about how accurate they would be (where I think they should be would be sighting through a hole that looks like a beaver chewed it). There is also a more refined hole on the carb side but there I'm looking at "teeth". Maybe they refined the design so I am on the same side of the machine as the points but I can't see any marks there either. But all in all, I deal with stock Kohler points that are positioned in a spot that makes them move before I can tighten to where I want them...so I rely on the static timing and it seems to work (.020 gap using a wire gauge that is probably closer to .018 now).
Old 09-19-2012, 08:36 PM
exactly why I asked..
These engines are set @ 20 degrees btdc correct? Not hard to bolt a scrape across the piston and find TDC. THen go over 20 degrees.
I'm sure within a few degrees there is very marginal difference in power or knock potential.
