Old 09-21-2012, 10:48 AM
wj-ihc's Avatar
wj-ihc wj-ihc is offline
Default K-241 vs K301 cranks
Does anyone know for sure if the cranks are interchangable between a 10 and 12 horse kohler. I believe the sizes are all the same, but I am curious if there was any difference in the balancing?
5x Originals, one with rear PTO, 70, 2x 100's, one w/ creeper,2x 102's, 2x 122 w/creeper and rear pto, 2x 123's, 105, 125 w/ aux hyd,2x 73's, 126, 2x 147, 86, 2x 108's, 129, 2x 149's, 169, 3x 800's, 2x 1100's, 1250, 3x 1650's, 682, 2x 782's, 782D, 982 w/60" Haban, 1872 w/ Haban deck
2 Rear Tillers, 1 Snowblower, #1 cart and 2x #2 cart
IH/Cub Cadet 79C Chipper
526 Front Tine Tiller
Brinly plow, disk, grader blade
Old 09-21-2012, 05:03 PM
Yes, the counterweights are different.
Old 09-21-2012, 05:24 PM
wj-ihc's Avatar
So a 301 piston in a 241 block/crank would be out of balance to some extent? What is the best way to identify a 10 or 12 crank.
Old 09-21-2012, 06:38 PM
cubs-n-bxrs's Avatar
The stroke is roughly about 3/8ths of an inch shorter on a 10hp vs the 12hp.
