My 1541 keeps throwing the deck belt off, all bearings, pulleys etc seem to be in good shape. I ordered a new tension/idler spring and that did make it last longer, still throwing the belt. I happen to have two 1541's and used the deck on the first coupled to a 1604 and cut grass with zero problems. I swapped the deck, still the deck belt come off, so I changed the mule drive, and still the deck belt come off !!
So I have eliminated the deck as the cause, and I also used a OEM belt, I'm scratching my head at this point. Could it be the PTO ? it seems to be working fine, but it came with a new in the box PTO, aftermarket, but still... maybe the bearings are shot and it's transferring vibrations to the deck drive ? Also looking at where the mule drive bolts (special bolt) to the hanger on parts tree is different than the way mine is, could the cause a problem ? I'm racking my brain, if anyone has had the problem or knows the solution please give me some ideas. Thanks, Clint |
Clint, pictures would help for us to see. Does the belt slap around a lot when the pto is turned on?
I'm fixing to pull the deck off now. I compared it to a 1440 with same type (not exact same model) but a GT 46" deck and the belt does not vibrate any more. When it comes off it goes under the deck pulleys .. Like I said I'm going to pull it off, I will take a picture of it and a picture is worth a thousand words !!
