Old 03-27-2009, 08:15 PM
Jim H.'s Avatar
Jim H. Jim H. is offline
Default Cheaper way to add weights in your tires.
I got permission of the poster to put it here, says the guy from even another forum told him.
I think this is a very good idea.
__________________________________________________ _______________
Here's what a guy on ***site sent to me as an option that he uses....
"I use plumbing antifreeze - it's non toxic compared to WWF. Add to it regular sugar at a rate of 30% of the antifreeze.... 1 lb of sugar for 3 lbs of liquid.
Plumbing antifreeze costs about $9 per 10L jug (2 & 2/3 gal), which translates to about $3.75 per gal. Sugar is cheap.
Now that antifreeze is good for -50 deg., so I diluted it 4:1 (4 parts antifreeze, 1 part water) - which will give me something in the range of -37 deg. stuff. If your winters are milder, you can go 50/50 to make it even cheaper.
My tractor took 4, 10L jugs (3 antifreeze + 1 water), plus 30 lbs of sugar, which gave me a total of almost 120 lbs per wheel. That's a super-turf tire, 23x10.5x12
If I didn't use sugar, I'd get 90 lbs per wheel.
I premixed the sugar in the plain water - used hot water to dissolve the sugar quickly. Then pured it in through the separated tire bead/rim...."
I would imagine if the water was boiled more sugar could be dissolved into it making the concentrate even heavier.
(Message edited by bbrigham on March 27, 2009)
Every time I find the key to success, someone changes the lock
Old 03-28-2009, 07:58 AM
Jim H:
OK...not being a Chemist, what is the reason for adding sugar to the Plumbing AntiFreeze..???
Old 03-28-2009, 10:34 AM
Jim H:
My guess would be extra weight.
Old 03-28-2009, 09:36 PM
FrankenCub FrankenCub is offline
You can dissolve a lot of sugar into the mix making the concentration even heavier.
Old 12-22-2013, 07:36 PM
And......Next summer when you are mowing........and if one of the tires is maybe...I don't know....seeping or leaking a tiny bit........
You may wind up with.....Ants in Yer pants!!!
I'm sorry,,,, just couldn't help myself there for a moment!!
Merry Christmas everyone!!!
