Old 10-14-2012, 09:22 AM
Shad0wjack Shad0wjack is offline
Default Cub Cadet 2166 pto switch ... HELP!!!
I have a 2166 Cub Cadet that will not start, I have tested the battery and fuses, I have tested the ignition switch with a meter and it tests out fine. I have also bypassed the seat and break switch until I figure out whats causing my problem. I can connect a hot wire from the batter to the solenoid blue wire position and it will turn over great but will not start. I have also ran a hot and ground to the pto clutch itself and i hear it engage. Can anyone tell me where I can find a good wiring diagram for the switch 723-3233(925-3233 replacement). Or can anyone tell me if there is a way to bypass this switch just to see if I can get the motor to spin and then I will know what is causing the issue. Thanks in advance.
Shad0wjack
Old 10-14-2012, 11:18 AM
also can anyone tell me where the engine connector is on this cadet
Old 10-14-2012, 02:00 PM
Pic from the Cub parts site.
