Old 10-30-2009, 09:40 PM
Stitch's Avatar
Stitch Stitch is offline
Default Checking fluid for hydraulic lift.....
My 100 has the hydraulic lift, so I assume I will need to routinely check the fluid for it. I've been looking and looking, and I don't find any way to do this. Am I missing something?
Killin deers and drinkin beers
Old 10-30-2009, 10:19 PM
Merk Merk is offline
The tank on the hydraulic pump should have a plug in it. The oil level should be to the bottom of the hole. I use Hy-Tran oil in my pump. The manual I have says you can use 10W in it too.
