I've been fighting the steering on my 1872 for a year. I switched the steering cylinder from the 2072 over to it, It just a bit better. I sent the cylinder to Kelly for a rebuild.
Now it steers like a dream!!!!!!!!!!!!!! THANK YOU KELLY !!!!!!!!!!!!!!!!!!!!
Now go fix that muffler! I still can't hear from plowin with ya.
That's awesome, Vince!
Vince anytime. That's what friends are for. Will be waiting for cylinder #2. Maybe I will paint this one a nice shade of peach or something like that. LOL
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
Did you see the pics of the muffler? The whole side blew out and the soot was so bad inside that Vince wrote his name on the side pannel! I traded Earl a set of wheel weights for that muffler he had on the trailer. Kelly You know me, Ill put it on the tractor, I dont care what color it is. Were you at the plow day when I painted Steves weight bracket pink and JD green? LMAO! |
Vince
You don't need no stinkin muffler, put a pair of 4" chrome stacks on it. Then you'll think your running a big tractor.
Could you provide information and or pictures on how you re-built the cylinder?
Thanks, Ike |
Sorry I can't provide pictures because I did the job at my work during my break times and cameras are frowned on. We must have top secret information here. Anyways chuck the cylinder up in a three jaw chuck in a good lathe and cut the weld off of the butt end of the cylinder and tap that end off. Push the shaft/piston out the end and replace the o-ring reinstall everything back in the cylinder body. Put the butt end back on and tack weld in a couple places to hold it. Make sure hydraulic ports are on the same line. Dont ask me how I know that. The first cylinder I rebuilt the hydraulic ports were 180 apart.
Pull the shaft all the way out to keep the new o-ring as far away from the heat as possible. I weld it in 4 segments cooling in a pail of water inbetween welds. It takes me all of about 25 minutes to do one from start to finish.
Hi,
Thanks much for the info. A few of us have been talking about the possibility of re-building them. Don't have one that needs done right now, (thats a good thing). When the time comes your info will be very helpful. Thanks, Ike |
Well I love a good joke, weather I play it on someone or they play it on me! Sent Kelly another cylinder, at least it wasnt JD green and pink!
