Old 10-31-2009, 01:11 PM
twheld twheld is offline
Default checking hyd level 125
I wanted to change the oil and filter on the hyd drive. didnt see any drain or fill location, any help with procedure Thanks Tadd
Old 10-31-2009, 01:17 PM
Pull the back cover to drain, there should also be a fill plug on the back cover. I find a funnel with a hose attached helps a lot when filling. Use a new gasket, sealer on the bolts is sometimes recommended. Hope ya got a BIG drain pan too.
Old 10-31-2009, 01:23 PM
Default 125 hydro
any idea how much oil it takes thanks Tadd
Old 10-31-2009, 02:29 PM
ajgross ajgross is offline
Inactive Member
It hold 7 quarts.
AJ
Old 10-31-2009, 05:17 PM
Merk Merk is offline
It sounds like you could use a Chassis Service Manual for your 125.
Here is a link to a Chassis Service Manual.
http://www.onlycubcadets.net/forum/showthread.php?t=230
It was found in our Technical Library section on this site.
