Old 10-27-2012, 04:49 AM
colt54 colt54 is offline
Default snow plow/dozer blade
Hello all
I have a question for you all about down Pressure on a snow/dozer blade.
I have a 129 with a manual lift that started my yellow fever.Since then I have bought a few other attachments for it.Now I found out Im misusing
my snow/dozer blade due to a button on the lift arm. Is this button a ez fix or not? I was told it is a flotation button. For my lifting rod is bending from the the lifting rod to the plow/dozer blade.
And if so how do the hydro lifts work with this down pressure. For I bought all I need to convert my 129 to a hydro lift
thanks Rod
Old 10-27-2012, 06:37 AM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
My 149 has the float built into the rockshaft. All you do is leave the top pin out of the lift arm. This thread will show you what you need. http://onlycubcadets.net/forum/showthread.php?t=9744
